Part Number: TMS570LS3137
Other Parts Discussed in Thread: TMDS570LS31HDK
Hello TI Team,
I am in the process of designing a custom PCB using the TMS570LS3137 microcontroller and would appreciate some guidance on best practices and available reference material.
I have gone through the datasheet and TRM, but I still have a few design-related questions:
Power Supply & Capacitor Selection
Recommended values and types (ceramic/tantalum) for:
Core, I/O, and analog supply decoupling
Bulk capacitors per power domain
Placement guidelines (distance from pins, via usage, etc.)
Clock Configuration
Clarification on the clock select / oscillator-related pins
Recommended crystal or oscillator specifications
Any PCB layout precautions for clock routing and grounding
Pin Functions & Configuration
Best practices for handling:
Boot configuration pins
Test / JTAG pins
Unused pins (pull-ups, pull-downs, or leave floating)
Any common mistakes to avoid during schematic capture
PCB Layout Guidelines
Stack-up recommendations (especially for EMI/ESD robustness)
Grounding and power plane considerations
High-speed signal routing tips (if applicable)
System-Level Documentation
Is there a System Design Guide, Hardware Design Guide, or reference schematic/PCB available specifically for the TMS570LS31xx family?
Any TI reference designs or application notes that you would recommend?
