Part Number: MSPM0L1105
Hi Ti Team,
Recently, while testing programming of the NONMAIN region on the MSPM0L1105TRGER, I found that when checking whether the NONMAIN region was blank after an erase operation, the NONMAIN region of this device was not completely erased.
If the erase status cannot be reliably confirmed, this may cause issues when writing data afterward.
In addition, I am also testing programming on the MSPM0C1106SRGER.
After programming, I am unable to read back the correct programmed data.
Based on my investigation, it appears that residual data from before programming may still remain inside the IC.
The correct data can be read only after resetting the IC; however, some customers’ programming files are unable to communicate after an IC reset.
I have also observed that when reading the same address twice, the second read returns the correct data.
Could you please advise how to resolve the issue of incomplete erase on the NONMAIN region of the MSPM0L1105TRGER?
Or is this behavior also related to reading residual internal data that existed before the erase operation?
As for the issue on the MSPM0C1106SRGER where pre-programming residual data is read, is it acceptable to resolve this by reading twice, or is there a more appropriate solution?
Thank you.
Steve.
