Part Number: AM2434
is it possible to use ethernet ports for regular tcp/ip packets
Part Number: AM2434
Hi Enis,
Yes, you can run TCP/IP stack for ethernet ports available on AM243x. You can configure them to be either in switch mode, where they can forward the packets between the ports, or you can also configure them to be in MAC mode, where you can configure them as ethernet endpoint nodes.
You can find examples available in the SDK to run LwIP TCP/IP stack. You can find the documentation to run the examples here: https://software-dl.ti.com/mcu-plus-sdk/esd/AM243X/latest/exports/docs/api_guide_am243x/EXAMPLES_NETWORKING.html
Please let us know if you need more details.
Thanks and regards,
Teja.
