AM3357: DDR 3 Alternate
Part Number: AM3357
I am seeking a replacement for the obsolete MT41J128M16JT-125:K TR memory used in the ICE evaluation board design. Can you provide a list of validated DDR3 alternatives that are footprint-compatible and supported by the AM3357.
Here are few options that I have found.
Manufacturer Part Number Type
Micron MT41K128M16JT-125:K DDR3L
Alliance Memory AS4C128M16D3LC-12BIN DDR3L
Kingston D1216ECMDXGJDI-U DDR3L
ISSI (Intelligent Memory) IM2G16D3FDBG-125I DDR3L
  • We don't have any lists of validated memories.  The AM335x DDR interface is compatible with JEDEC compliant memories.  If the devices you choose are JEDEC compatible (which i believe all those listed except for the last one), then they should be compatible with AM335x.  You might need a slightly different DDR configuration, which can be obtained using the EMIF tool for AM335x:   https://www.ti.com/lit/pdf/sprack4
    Note, ISSI and Intelligent Memory are two different vendors.  The part number you quote is from IM, but the datasheet does not claim JEDEC compliance.
    James
