Part Number: TM4C1294NCPDT
Other Parts Discussed in Thread: EK-TM4C1294XL, EK-TM4C123GXL
Hello TI Team,
I am working with the TM4C1294NCPDT (EK-TM4C1294XL LaunchPad) and trying to run the USB Mass Storage Class (MSC) Host example to interface a USB Pen Drive. Unfortunately, during my previous attempts, my TIVA board stopped working, so I want to confirm the correct and safe hardware setup before trying again.
I would appreciate your guidance on the following:
Exact USB Pin Connections
Correct mapping of USB0DM, USB0DP, VBUS, ID, and GND when connecting a USB Type-A female connector for Pen Drive (Host mode).
Any required configuration for the ID pin for forcing Host mode.
Power Requirements
Proper way to supply 5V VBUS to the USB Pen Drive.
Can the LaunchPad supply sufficient current directly, or is an external 5V supply required?
Recommended method to avoid damaging the MCU or board.
Protection / Safety Components
Do we need:
Series resistors on D+ / D− lines?
ESD protection diodes?
Power switch / current limiting IC for VBUS?
Any reference schematic for safe USB Host hardware implementation using TM4C1294.
Clock / Software Prerequisites
Any mandatory USB clock configuration required in hardware (25 MHz crystal already present on LaunchPad).
Anything specific to verify before running the USB MSC example.
Reference Design
Is there any TI official schematic, app note, or tested circuit showing a safe USB Host connection for a Pen Drive with TM4C1294?
Since one of my boards was damaged earlier, I want to be absolutely sure about the correct wiring and required protection before retrying.
Thank you for your support.
Tanuj
