MSPM0G3519: Firmware upgrade Procedure
Part Number: MSPM0G3519
Other Parts Discussed in Thread: MSPM0C1104, UNIFLASH, MSPM0G3518
I am working on MSPM0G3519 Launchpad. I want to do OTA based firmware upgrade. I have 2 codes. 1st is bootloader code where i changed the flash region in linker.cmd file
FLASH           (RX)  : origin = 0x00000000, length = 0x00008000.
in this bootloader code, I am receiving the .bin file through bluetooth and storing in location starting from 0x00008000. after completion i want to check whether application is valid or not and if valid i want to jump to application.
int is_application_valid(void)
    uint32_t stack = *(uint32_t*)APP_VECTOR_ADDRESS;
   // __BKPT(0);
   // if ((stack & 0xFFF00000) == 0x20200000)
    if ((stack & 0x2FFE0000) == 0x20200000){
        jump_flag = 1;
        result = 1;
    else{
        result = 2;
    return result;
void jump_to_application(void)
    uint32_t *vectorTable = (uint32_t *)APP_VECTOR_ADDRESS;
    uint32_t appStack = vectorTable[0];
    uint32_t appReset = vectorTable[1];
    __disable_irq();
    /* Disable all NVIC interrupts */
    for(int i = 0; i < 8; i++)
        NVIC->ICER[i] = 0xFFFFFFFF;   // Disable
        NVIC->ICPR[i] = 0xFFFFFFFF;   // Clear pending
    /* Disable SysTick */
    SysTick->CTRL = 0;
    SCB->VTOR = APP_VECTOR_ADDRESS;
    __set_MSP(appStack);
     void (*appEntry)(void) = (void (*)(void))appReset;
    appEntry();
In my application code linker.cmd file is as below.
MEMORY
    FLASH           (RX)  : origin = 0x00008000, length = 0x00078000
    SRAM_BANK0      (RWX) : origin = 0x20200000, length = 0x00010000
    SRAM_BANK1      (RWX) : origin = 0x20210000, length = 0x00010000
    BCR_CONFIG      (R)   : origin = 0x41C00000, length = 0x000000FF
    BSL_CONFIG      (R)   : origin = 0x41C00100, length = 0x00000080
    DATA            (R)   : origin = 0x41D00000, length = 0x00004000
SECTIONS
    .intvecs:  {}  > 0x00008000
    .text   : palign(8) {} > FLASH
    .const  : palign(8) {} > FLASH
    .cinit  : palign(8) {} > FLASH
    .pinit  : palign(8) {} > FLASH
    .rodata : palign(8) {} > FLASH
    .ARM.exidx    : palign(8) {} > FLASH
    .init_array   : palign(8) {} > FLASH
    .binit        : palign(8) {} > FLASH
    .TI.ramfunc   : load = FLASH, palign(8), run=SRAM_BANK0, table(BINIT)
    .vtable :   > SRAM_BANK0
    .args   :   > SRAM_BANK0
    .data   :   > SRAM_BANK0
    .bss    :   > SRAM_BANK0
    .sysmem :   > SRAM_BANK0
    .TrimTable :  > SRAM_BANK0
    .stack  :   > SRAM_BANK0 (HIGH)
    .BCRConfig  : {} > BCR_CONFIG
    .BSLConfig  : {} > BSL_CONFIG
    .DataBank   : {} > DATA
and in application code main() i have used
SCB->VTOR = 0x00008000;
I build the project and generated the .bin file. I have attached the screenshots for the .bin file for after converting to hex view and another screenshot showing the memory view where this value has stored.  After storing when I am checking for is_application_valid(), in the if condition, it is entering into some default handler and I am not able to come out of the loop. what is happening I am not understanding. I am sharing the main() function too.
int main(void)
    SYSCFG_DL_init();
    __enable_irq();
    DL_UART_Main_enable(UART_1_INST);
    NVIC_EnableIRQ(UART_1_INST_INT_IRQN);
    delay_ms(3000);
    /*if(is_application_valid())
        __BKPT(0);
        jump_to_application();
    // DO NOT ERASE HERE
    while(1)
        delay_ms(1);
        lastReceiveTime++;
        if(lastReceiveTime > 2000)
            if(rxIndex >= 8)
                uint16_t fullBlocks = rxIndex / 8;
                for(int i = 0; i < fullBlocks * 8; i += 8)
                    flash_write_block(&rxBuffer[i]);
                rxIndex = 0;
if(lastReceiveTime > 20000){
            __disable_irq();
                __BKPT(0);
I want to know Is this the correct way to do firmware upgrade? or Is there any other way to do this?
I need guidance on this. It's very urgent. I got stuck on it.
  • Till now my code is working fine with uart0.
    Dose that mean when you use the uart0 it not need the reset? When change to uart1 It need reset to make the firmware to run?
  • Hi Gary,
    Sorry for the late response. Yesterday I was on leave. Yes , whatever you are saying is correct. with UART0 there is no need to press the reset button in power On. When I am adding UART1, at every power ON need to press the reset button. after that the code is running
    I have removed
    NVIC_EnableIRQ(UART_0_INST_INT_IRQN); from my code, then the code is running at power on.
    But at power On when I am doing firmware upgrade, it's not working.
    But when I am using Uart0, everytime at power on firmware upgrade is working.
    with uart1, only in debug mode firmware upgrade is working.
    Now what is the difference, how to solve this issue.
    I am receiving the firmware, but jump_to_application() is not working. same code is working with uart0 in debug mode as well as power on mode. but with uart1 it is working only with debug mode not in power on mode
  • First let me clarify the issue first. For the MSPM0G3519 as target device, how do it get the new firmware? UART?
    If so, assume you use UART0 to get the firmware, it work well. For UART1 what do you do use to use it? Replace the UART0 to get the firmware?
    How do you trigger the device into BSL? By GPIO or software invoke?
    By software invoke. I took the example code of bsl by software invoke. I connected the BLE module to PA8 and PA9 . Instead of sending bsl packets  I am sending the hex bytes of the application code and storing it in 0x00058000. After completion of receiving I am copying the application code from 0x00058000 to 0x00008000. And calling jump to application function.
  • Hi Gary,
    Thanks for your help, At power ON I was receiving garbage data that's why firmware was not upgrading. Now I found the problem.
