Part Number: MSPM0G3519
Dear,
We have the following issue using MCAN0 on MSPM0G3519.
CAN_CLK = 80MHZ
Please see XLS find attached.
The first XLS tab contains a logging on oscilloscope (but have same using PCAN).
We send 588 frames into TX FIFO from node A to node B.
You can see at the in the read lines that 2 messages have wrong identifier and data.
This only happens in the case the that the node B is sending also frames (0x700) on the bus.
If we don't send frames (0x700) from node B to node A, we allways receive the 588 packages in node B (coming from node A).
The other tabs in the XLS files contain the configuration code of the MCAN0.
We are sure that we don't send the frames in the red lines by mistake.
Looking for help.
John
