AM13E23019: Missing information regarding IO Structure in datasheet
Part Number: AM13E23019
In the datasheet the information regarding "IO structure" (Standard, High-speed, High-drive) for specific pin is missing.Referred in TRM: image
Best Regards
Aafiya
  • Hey Aafiya,
    Thank you for bringing this to our attention. I will file a ticket to get this resolved. The information will be made available as a new column in the Pin Attributes table for the next release of the datasheet.
    In the mean time, please refer to the table below.
    Pin PINCM IO Type
    PC2 66 SDL
    PC3 67 SDL
    PC4 68 SDL
    PC5 69 SDL
    PC6 70 SDW
    VDD_0 PWR
    PB13 45 SDW
    PB14 46 SDL
    PB15 47 SDL
    PC19 83 SDL
    PC20 84 SDL
    VSS_0 GND
    VDD_1 PWR
    PC21 85 SDL
    PC23 87 SDL
    PC24 88 SDL
    PC25 89 SDL
    PC26 90 SDL
    PC16_X1 80 SDL
    PC17_X2 81 SDL
    NRST 106 NRST
    PB0 32 SDL
    PB1 33 SDW
    PB2 34 SDL
    PB3 35 SDL
    VSS_1 GND
    VREFLO0 VREF/FLT
    VREFHI0 VREF/FLT
    PC18 82 SDL
    PA0 0 SDW
    PA1 1 SDL
    PA2 2 SDW
    VSSA_0 GND
    VSSA_1 GND
    VDDA_0 PWR
    VDDA_1 PWR
    PA3 3 SDL
    VSSA_2 GND
    VSSA_3 GND
    VDDA_2 PWR
    VDDA_3 PWR
    PA4 4 SDL
    PA5 5 SDL
    PA6 6 SDL
    PA7 7 SDL
    PB4 36 SDL
    PB5 37 SDW
    PA16 16 SDL
    PA17 17 SDL
    PA18 18 SDL
    VSSA_4 GND
    VREFLO1 VREF/FLT
    VREFHI1 VREF/FLT
    VDDA_4 PWR
    VSS_2 GND
    VDD_2 PWR
    PC27 91 SDL
    PC28 92 SDL
    PC29 93 SDL
    PC30 94 SDL
    PC31 95 SDL
    PC7 71 SDL
    PC8 72 SDL
    PC9 73 SDL
    PC10 74 SDL
    PC11 75 SDL
    PC12 76 SDL
    PC13 77 SDL
    PC14 78 SDL
    PC15 79 SDL
    PA26 26 SDL
    NC NA
    VSS_3 GND
    VSS_4 GND
    VDD_3 PWR
    PA27 27 SDL
    PA28 28 SDL
    PA29 29 SDL
    PA30 30 SDL
    PA31 31 SDL
    VDD_4 PWR
    PB24 56 SDL
    PB25 57 SDL
    PB26 58 SDL
    PB27 59 SDL
    PB28 60 SDL
    PB29 61 SDL
    PB30 62 SDL
    PB31 63 SDL
    VSS_5 GND
    VDD_5 PWR
    PB6 38 SDL
    PB7 39 SDL
    PD0 96 SDL
    PD1 97 SDL
    PD2 98 SDL
    PD3 99 SDL
    PD4 100 SDL
    PB8 40 SDL
    PB9 41 SDL
    PA8 8 SDL
    PA9 9 SDL
    PA10 10 SDL
    VDD_6 PWR
    VDD_7 PWR
    PA11 11 SDL
    PA12 12 HS
    VSS_6 GND
    VDD_8 PWR
    VDD_9 PWR
    PA13 13 SDL
    PC22 86 SDL
    VSS_7 GND
    VDD_10 PWR
    VDD_11 PWR
    PA14 14 SDL
    PA15 15 HS
    PB10 42 SDL
    PB11 43 SDL
    PB12 44 SDL
    PD5 101 SDL
    PD6 102 SDL
    PD7 103 SDL
    PD8 104 SDL
    PD9 105 SDL
    PB16 48 SDL
    PB17 49 SDL
    VSS_8 GND
    VDD_12 PWR
    PB18 50 HS
    PB19 51 SDW
    PB20 52 SDL
    PB21 53 SDL
    PB22 54 SDL
    PB23 55 SDL
    PA19 19 HS
    PA20 20 SDL
    PA21 21 SDL
    PA22 22 SDL
    PA23 23 SDL
    PD11 107 SDL
    PA24 24 SDL
    PA25 25 SDL
    PC0 64 SDL
    PC1 65 SDL
    VSS_9 GND
    VSS_10 GND
    VDD_13 PWR
    VDD_14 PWR
    VDD_15 PWR
    Zackary Fleenor
  • Hi Zackary Fleenor! I noticed that the drive strength for the PB18 pin can be adjusted in PINCM register, but in this table, the PB18 is listed as SDL. Could you please check this?
    BR,
    Danylo Plotskykh
  • Hey Danylo,
    You are correct, this is a typo in the table. PB18 is an HS IO type. I will fix the original response and make sure this is reflected in the updated datasheet table.
    Zackary Fleenor
