AM625: About Am62 and DP83867
Part Number: AM625
Hello
An issue was found with AM625 linux5.16 and dp83867:
When the power supply of my som board is normal and phy is powered off, there are no abnormal outputs related to phy in Linux. My IP link set and some applications implementing TCP and other operations will be blocked, and subsequent operations cannot be executed properly.
Hao
    At the moment I am not able to fully follow what you are describing. Could you please explain what you are describing in relation to abnormal outputs?
    From a driver perspective the interface will not function unless there is link partner connected to the PHY.
    Schuyler
