Part Number: AM13E23019
When will the OSX installer for AM13E230 show up? Right now there's only the windows and Linux installers?
Also, as a temporary workaround, I cloned the github repo and used that instead.
One suggestion in the makefile for the git repo is to have it "install" a "lib" directory where the traditional SDK has the "source/lib" directory. I just symlinked this from "build/am13e230x/lib". Or we could have an actual install step that copies the build artifacts to the correct SDK directory.
This way you can import and build projects in CCS as well as with the command line build.
Munan
