AM62L: OPTEE is not loaded with SDK11.2
Part Number: AM62L
From the UBoot log, OPTEE is not loaded. no matter boot with prebuit .wic file made SD card, or with new build PRNG OPTEE uboot boot from eMMC, same log as below I got on AM62L EVM
Since TEE is not loaded, PRNG TEE or OOB TEE should not impact rt-linux cyclictest result.
NOTICE:  BL1: Built : 10:58:06, Feb  2 2026
NOTICE:  BL1: dram_class: 11
NOTICE:  lpddr4: post start - PI training status=0x27c0a000
NOTICE:  bl1_platform_setup DDR init done
NOTICE:  k3_bl1_handoff ENTERING WFI - end of bl1
NOTICE:  BL31: v2.12.0(release):11.02.01-14-g5939ceaeb
NOTICE:  BL31: Built : 10:58:08, Feb  2 2026
NOTICE:  SYSFW ABI: 4.0 (firmware rev 0x000b '11.2.5-v11.02.05a (Fancy Rat)')
get_device_type a0a
I/TC:
I/TC: OP-TEE version: 4.7.0 (gcc version 13.4.0 (GCC)) #3 Mon May 25 02:25:05 UTC 2026 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check optee.readthedocs.io/.../porting_guidel
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: Primary CPU switching to normal world boot
ERROR:   Agent 0 Protocol 0x10 Message 0x7: not supported
U-Boot SPL 2025.01-g7493977a537f-dirty (May 25 2026 - 10:39:16 +0800)
SPL initial stack usage: 1984 bytes
Trying to boot from MMC1
U-Boot 2025.01-g7493977a537f-dirty (May 25 2026 - 10:39:16 +0800)
SoC:   AM62LX SR1.1 HS-FS
Model: Texas Instruments AM62L3 Evaluation Module
DRAM:  2 GiB
Core:  85 devices, 32 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   eth0: ethernet@8000000port@1
Warning: ethernet@8000000port@2 (eth1) using random MAC address - 9e:1a:69:29:a1:a1
, eth1: ethernet@8000000port@2
Hit any key to stop autoboot:  0
Can grep out TEE in dmesg:
root@am62lxx-evm:~# uname -a
Linux am62lxx-evm 6.12.57-ti-rt-g31b07ab8dfbc #1 SMP PREEMPT_RT Thu Dec 4 13:07:37 UTC 2025 aarch64 GNU/Linux
root@am62lxx-evm:~#
root@am62lxx-evm:~# dmesg |grep tee
[ 0.000000] OF: reserved mem: 0x0000000080200000..0x00000000809fffff (8192 KiB) nomap non-r
[ 0.991337] optee: probing for conduit method.
[ 0.991379] optee: revision 4.7 (a9690ae39995af36)
[ 0.991801] optee: dynamic shared memory is enabled
[ 0.992884] optee: initialized driver
root@am62lxx-evm:~#
But under Customer's system, does the optee not effected?
[ 1.338980] optee: probing for conduit method.
[ 1.338998] optee: api uid mismatch
[ 1.339004] optee firmware:optee: probe with driver optee failed with error -22
  • Hi Tony,
    I'm attaching two logs with AM62L Linux SDK 11.2.8.2 on AM62L EVM
    - am62l_11.2.8.2_optee_dbg.log: TRNG
    - am62l_11.2.8.2_optee_dbg_prng.log: PRNG
    -Hong
    NOTICE:  bl1_plat_arch_setup arch setup
    NOTICE:  Booting Trusted Firmware
    NOTICE:  BL1: v2.12.0(release):11.02.01-14-g5939ceaeb
    NOTICE:  BL1: Built : 21:51:41, Jan 13 2026
    NOTICE:  BL31: Built : 21:51:42, Jan 13 2026
    get_device_type a0a
    I/TC:
    I/TC: OP-TEE version: 4.7.0-47-ga9690ae39 (gcc version 13.4.0 (GCC)) #1 Tue Feb  3 21:57:19 UTC 2026 aarch64
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: EIP76D TRNG initialized
    I/TC: DTHEv2 Drivers initialized
    U-Boot SPL 2025.01-g7493977a537f (Feb 03 2026 - 16:01:22 -0600)
    Trying to boot from MMC2
    U-Boot 2025.01-g7493977a537f (Feb 03 2026 - 16:01:22 -0600)
    DRAM:  2 GiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Warning: ethernet@8000000port@2 (eth1) using random MAC address - ea:2c:df:b0:12:b2
    Hit any key to stop autoboot:  2  0
    get_device_type a0a
    I/TC:
    I/TC: OP-TEE version: 4.7.0-47-ga9690ae39 (gcc version 13.4.0 (GCC)) #1 Tue Feb  3 22:09:05 UTC 2026 aarch64
    U-Boot SPL 2025.01-g7493977a537f (Feb 03 2026 - 16:10:46 -0600)
    U-Boot 2025.01-g7493977a537f (Feb 03 2026 - 16:10:46 -0600)
    DRAM:  2 GiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Warning: ethernet@8000000port@2 (eth1) using random MAC address - 22:72:4a:e7:66:6f
  • Hong,
    OPTEE load address from Linux user guide, Although custom board is 512MB DDR which should not be a problem for OPTEE loading.
    | ATF image                 | 0x80000000 |
    | OP-TEE image              | 0x80200000 |
    | U-Boot/Linux kernel image | 0x80080000 |
    | DTB                       | 0x82000000 |
    Below is log from customer board, there is not I/TC stage log which report OP-TEE information.
    Seems the u-boot.img has not OPTEE combined.
    NOTICE: BL1: v2.12.0(release):11.02.01-14-g5939ceaeb-dirty
    NOTICE: BL1: Built : 08:05:07, Jan 28 2026
    NOTICE: BL1: dram_class: 10
    NOTICE: lpddr4: post start - PI training status=0x29c02000
    NOTICE: BL31: v2.12.0(release):11.02.01-14-g5939ceaeb-dirty
    NOTICE: BL31: Built : 08:05:11, Jan 28 2026
    get_device_type a0a
    U-Boot SPL 2025.01-g398f44b6f7db (Apr 30 2026 - 03:21:19 +0000)
    SPL initial stack usage: 2048 bytes
    Trying to boot from SPINAND
    Customer uboot building log:
    root@linux-VMware-Virtual-Platform:/home/linux/hx1004086/product_TM740/ti-u-boot-2025.01+git# make CROSS_COMPILE="$CROSS_COMPILE_64" am62l3_plc_defconfig O=../uout
    make[1]: Entering directory '/home/linux/hx1004086/product_TM740/uout'
      GEN     Makefile
    # configuration written to .config
    make[1]: Leaving directory '/home/linux/hx1004086/product_TM740/uout'
    root@linux-VMware-Virtual-Platform:/home/linux/hx1004086/product_TM740/ti-u-boot-2025.01+git# make CROSS_COMPILE="$CROSS_COMPILE_64" \
            BL1=${TFA_DIR}/build/k3/am62l/release/bl1.bin \
            BL31=${TFA_DIR}/build/k3/am62l/release/bl31.bin \
            BINMAN_INDIRS=${TI_LINUX_FW_DIR} \
            TEE=${TI_LINUX_FW_DIR}/bl32.bin \
            O=../uout
      GEN     Makefile
    scripts/kconfig/conf  --syncconfig Kconfig
      CFG     u-boot.cfg
      GEN     include/autoconf.mk
      GEN     include/autoconf.mk.dep
      CFG     spl/u-boot.cfg
      GEN     spl/include/autoconf.mk
      Using /home/linux/hx1004086/product_TM740/ti-u-boot-2025.01+git as source for U-Boot
      GEN     Makefile
      UPD     include/generated/timestamp_autogenerated.h
      ENVC    include/generated/env.txt
      ENVP    include/generated/env.in
      ENVT    include/generated/environment.h
      CC      common/version.o
      AR      common/built-in.o
      CC      drivers/rtc/emul_rtc.o
      AR      drivers/rtc/built-in.o
      AR      drivers/built-in.o
      CC      env/common.o
      AR      env/built-in.o
      CC      lib/efi_selftest/efi_selftest_miniapp_exception.o
      LD      lib/efi_selftest/efi_selftest_miniapp_exception_efi.so
      OBJCOPY lib/efi_selftest/efi_selftest_miniapp_exception.efi
    lib/efi_selftest/../../tools/file2include lib/efi_selftest/efi_selftest_miniapp_exception.efi > \
    lib/efi_selftest/efi_miniapp_file_image_exception.h
      CC      lib/efi_selftest/efi_selftest_exception.o
      CC      lib/efi_selftest/efi_selftest_miniapp_exit.o
      LD      lib/efi_selftest/efi_selftest_miniapp_exit_efi.so
      OBJCOPY lib/efi_selftest/efi_selftest_miniapp_exit.efi
    lib/efi_selftest/../../tools/file2include lib/efi_selftest/efi_selftest_miniapp_exit.efi > \
    lib/efi_selftest/efi_miniapp_file_image_exit.h
      CC      lib/efi_selftest/efi_selftest_load_file.o
      CC      lib/efi_selftest/efi_selftest_loadimage.o
      CC      lib/efi_selftest/efi_selftest_startimage_exit.o
      CC      lib/efi_selftest/efi_selftest_miniapp_return.o
      LD      lib/efi_selftest/efi_selftest_miniapp_return_efi.so
      OBJCOPY lib/efi_selftest/efi_selftest_miniapp_return.efi
    lib/efi_selftest/../../tools/file2include lib/efi_selftest/efi_selftest_miniapp_return.efi > \
    lib/efi_selftest/efi_miniapp_file_image_return.h
      CC      lib/efi_selftest/efi_selftest_startimage_return.o
      AR      lib/efi_selftest/built-in.o
      AR      lib/built-in.o
      KSL     keep-syms-lto.c
      KSLCC   keep-syms-lto.o
      LTO     u-boot
      OBJCOPY u-boot.srec
      OBJCOPY u-boot-nodtb.bin
      RELOC   u-boot-nodtb.bin
      CAT     u-boot-fit-dtb.bin
      COPY    u-boot.bin
      SYM     u-boot.sym
      CC      spl/common/spl/spl.o
      AR      spl/common/spl/built-in.o
      CC      spl/env/common.o
      AR      spl/env/built-in.o
      KSL     spl/keep-syms-lto.c
      KSLCC   spl/keep-syms-lto.o
      LTO     spl/u-boot-spl
      OBJCOPY spl/u-boot-spl-nodtb.bin
      CAT     spl/u-boot-spl-dtb.bin
      COPY    spl/u-boot-spl.bin
      SYM     spl/u-boot-spl.sym
      MKIMAGE u-boot.img
      MKIMAGE u-boot-dtb.img
      BINMAN  .binman_stamp
      OFCHK   .config
    Can you give some idea why OPTEE is not loaded?
  • Hi Tony,
    I'm attaching a working log with AM62L Linux SDK 11.2.8.2 on AM62L EVM, where I re-configured DDR size as 512MiB as it is on the customer board.
    root@am62lxx-evm:~# dmesg | grep tee
    [    0.000000] OF: reserved mem: 0x0000000080200000..0x00000000809fffff (8192 KiB) nomap non-reusable optee@80200000
    [    1.084818] optee: probing for conduit method.
    [    1.089413] optee: revision 4.7 (a9690ae39995af36)
    [    1.106198] optee: dynamic shared memory is enabled
    [    1.117063] optee: initialized driver
    root@am62lxx-evm:~#
    "I/TC..." is displayed only when optee is built with "CFG_TEE_CORE_DEBUG=y".
    - this is where optee is linked into tispl.bin
    https://git.ti.com/cgit/ti-u-boot/ti-u-boot/tree/arch/arm/dts/k3-am62l3-evm-binman.dtsi?h=11.02.08#n99
    - this is the optee load address/length reserved in DDR caveout for AM62L
    https://git.ti.com/cgit/ti-u-boot/ti-u-boot/tree/arch/arm/mach-k3/Kconfig?h=11.02.08#n167
    https://git.ti.com/cgit/ti-u-boot/ti-u-boot/tree/arch/arm/mach-k3/am62lx/am62l3_fdt.c?h=11.02.08#n14
    -Hong
    get_device_type a0a
    I/TC:
    I/TC: OP-TEE version: 4.7.0-47-ga9690ae39 (gcc version 13.4.0 (GCC)) #1 Wed Mar  4 21:11:37 UTC 2026 aarch64
    U-Boot SPL 2025.01-g7493977a537f-dirty (May 28 2026 - 14:28:52 -0500)
    U-Boot 2025.01-g7493977a537f-dirty (May 28 2026 - 14:28:52 -0500)
    DRAM:  512 MiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Warning: ethernet@8000000port@2 (eth1) using random MAC address - 66:d2:3b:55:70:cd
    => bdinfo
    boot_params = 0x0000000000000000
    DRAM bank   = 0x0000000000000000
    -> start    = 0x0000000080000000
    -> size     = 0x0000000020000000
    flashstart  = 0x0000000000000000
    flashsize   = 0x0000000000000000
    flashoffset = 0x0000000000000000
    baudrate    = 115200 bps
    relocaddr   = 0x000000009feab000
    reloc off   = 0x000000001beab000
    Build       = 64-bit
    current eth = ethernet@8000000port@1
    ethaddr     = 30:30:d0:97:21:47
    IP addr     = <NULL>
    fdt_blob    = 0x000000009de7b7c0
    multi_dtb_fit= 0x0000000000000000
    lmb_dump_all:
     memory.count = 0x1
     memory[0]	[0x80000000-0x9fffffff], 0x20000000 bytes, flags: none
     reserved.count = 0x2
     reserved[0]	[0x9ce78000-0x9ce7afff], 0x3000 bytes, flags: no-notify, no-overwrite
     reserved[1]	[0x9ce7b7b0-0x9fffffff], 0x3184850 bytes, flags: no-overwrite
    devicetree  = separate
    serial addr = 0x0000000002800000
     width      = 0x0000000000000000
     shift      = 0x0000000000000002
     clock      = 0x0000000002dc6c00
    arch_number = 0x0000000000000000
    TLB addr    = 0x000000009fff0000
    irq_sp      = 0x000000009de7b7b0
    sp start    = 0x000000009de7b7b0
    Early malloc usage: 3640 / 8000
    => boot
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    610 bytes read in 3 ms (198.2 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    22391296 bytes read in 930 ms (23 MiB/s)
    50870 bytes read in 5 ms (9.7 MiB/s)
    Working FDT set to 80c00000
    ## Flattened Device Tree blob at 80c00000
       Booting using the fdt blob at 0x80c00000
       Loading Device Tree to 000000008fef0000, end 000000008fffffff ... OK
    Working FDT set to 8fef0000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.12.57-ti-g31b07ab8dfbc (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Thu Dec  4 13:07:37 UTC 2025
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Texas Instruments AM62L3 Evaluation Module
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: legacy bootconsole [ns16550a0] enabled
    [    0.000000] OF: reserved mem: 0x0000000080000000..0x00000000801fffff (2048 KiB) nomap non-reusable tfa@80000000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x000000009fffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x00000000809fffff]
    [    0.000000]   node   0: [mem 0x0000000080a00000-0x000000009fffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
    [    0.000000] cma: Reserved 32 MiB at 0x000000009d600000 on node -1
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] psci: OSI mode supported.
    [    0.000000] percpu: Embedded 22 pages/cpu s51736 r8192 d30184 u90112
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS0,115200n8 vt.global_cursor_default=0 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=da7369e3-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 131072
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 0MB
    [    0.000000] software IO TLB: area num 2.
    [    0.000000] software IO TLB: mapped [mem 0x000000009d540000-0x000000009d5c0000] (0MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
    [    0.000000] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=2.
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001840000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @81400000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080c40000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080c50000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008638] Console: colour dummy device 80x25
    [    0.013242] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023905] pid_max: default: 32768 minimum: 301
    [    0.028711] LSM: initializing lsm=capability,selinux
    [    0.033836] SELinux:  Initializing.
    [    0.037882] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
    [    0.045350] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
    [    0.055684] rcu: Hierarchical SRCU implementation.
    [    0.060646] rcu: 	Max phase no-delay instances is 1000.
    [    0.066195] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.074975] EFI services will not be available.
    [    0.079880] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.093131] Detected VIPT I-cache on CPU1
    [    0.093234] GICv3: CPU1: found redistributor 1 region 0:0x0000000001860000
    [    0.093252] GICv3: CPU1: using allocated LPI pending table @0x0000000080c60000
    [    0.093307] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.093501] smp: Brought up 1 node, 2 CPUs
    [    0.122844] SMP: Total of 2 processors activated.
    [    0.127646] CPU: All CPU(s) started at EL2
    [    0.131844] CPU features: detected: 32-bit EL0 Support
    [    0.137093] CPU features: detected: CRC32 instructions
    [    0.142377] alternatives: applying system-wide alternatives
    [    0.148670] Memory: 441320K/524288K available (13056K kernel code, 1258K rwdata, 4676K rodata, 2752K init, 643K bss, 43832K reserved, 32768K cma-reserved)
    [    0.163631] devtmpfs: initialized
    [    0.174207] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.184200] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.192221] 27120 pages in range for non-PLT usage
    [    0.192248] 518640 pages in range for PLT usage
    [    0.197578] pinctrl core: initialized pinctrl subsystem
    [    0.208196] DMI not present or invalid.
    [    0.214388] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.221904] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
    [    0.229652] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.238041] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.246218] audit: initializing netlink subsys (disabled)
    [    0.252180] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
    [    0.252689] thermal_sys: Registered thermal governor 'step_wise'
    [    0.260130] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.266327] cpuidle: using governor menu
    [    0.277218] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.284233] ASID allocator initialised with 65536 entries
    [    0.296023] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.307534] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/tps6598x@3f/connector
    [    0.319580] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.329465] /bus@f0000/i2c@20020000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.341493] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.354598] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/tps6598x@3f/connector
    [    0.367252] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.377248] /bus@f0000/i2c@20020000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.389577] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.399513] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.410656] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.419921] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.431307] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.438251] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.444665] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.451593] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.457990] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.464915] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.471312] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.478238] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.487071] k3-chipinfo 43000014.chipid: Family:AM62LX rev:SR1.1 JTAGID[0x1bba702f] Detected
    [    0.497290] iommu: Default domain type: Translated
    [    0.502230] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.508949] SCSI subsystem initialized
    [    0.513369] usbcore: registered new interface driver usbfs
    [    0.519013] usbcore: registered new interface driver hub
    [    0.524478] usbcore: registered new device driver usb
    [    0.530154] pps_core: LinuxPPS API ver. 1 registered
    [    0.535239] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.544576] PTP clock support registered
    [    0.548625] EDAC MC: Ver: 3.0.0
    [    0.552306] scmi_core: SCMI protocol bus registered
    [    0.557792] FPGA manager framework
    [    0.561643] Advanced Linux Sound Architecture Driver Initialized.
    [    0.568973] vgaarb: loaded
    [    0.572271] clocksource: Switched to clocksource arch_sys_counter
    [    0.578844] VFS: Disk quotas dquot_6.6.0
    [    0.582895] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.598135] NET: Registered PF_INET protocol family
    [    0.603338] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.611511] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
    [    0.620154] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.628088] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.636033] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.643524] TCP: Hash tables configured (established 4096 bind 4096)
    [    0.650144] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
    [    0.656831] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
    [    0.664124] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.670523] RPC: Registered named UNIX socket transport module.
    [    0.676616] RPC: Registered udp transport module.
    [    0.681419] RPC: Registered tcp transport module.
    [    0.686220] RPC: Registered tcp-with-tls transport module.
    [    0.691819] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.698416] NET: Registered PF_XDP protocol family
    [    0.703329] PCI: CLS 0 bytes, default 64
    [    0.708712] Initialise system trusted keyrings
    [    0.713643] workingset: timestamp_bits=46 max_order=17 bucket_order=0
    [    0.720687] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.727101] NFS: Registering the id_resolver key type
    [    0.732356] Key type id_resolver registered
    [    0.736634] Key type id_legacy registered
    [    0.740759] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.747603] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.809308] Key type asymmetric registered
    [    0.813522] Asymmetric key parser 'x509' registered
    [    0.818628] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.826436] io scheduler mq-deadline registered
    [    0.831087] io scheduler kyber registered
    [    0.835238] io scheduler bfq registered
    [    0.842259] pinctrl-single 4084000.pinctrl: 147 pins, size 588
    [    0.850125] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.858274] ti-udma-am62l 485c4000.dma-controller: Number of rings: 144
    [    0.865230] ti-udma-am62l 485c4000.dma-controller: Channels: 144 (bchan: 16, tchan + rchan: 128)
    [    0.881083] ti-udma-am62l 485c0000.dma-controller: Number of rings: 112
    [    0.887999] ti-udma-am62l 485c0000.dma-controller: Channels: 97 (tchan + rchan: 97)
    [    0.904981] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.924049] loop: module loaded
    [    0.928569] megasas: 07.727.03.00-rc1
    [    0.936753] tun: Universal TUN/TAP device driver, 1.6
    [    0.943263] VFIO - User Level meta-driver version: 0.3
    [    0.949828] usbcore: registered new interface driver usb-storage
    [    0.956708] i2c_dev: i2c /dev entries driver
    [    0.962886] sdhci: Secure Digital Host Controller Interface driver
    [    0.969307] sdhci: Copyright(c) Pierre Ossman
    [    0.973998] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.982500] arm-scmi arm-scmi.0.auto: Using scmi_smc_transport
    [    0.988588] arm-scmi arm-scmi.0.auto: SCMI max-rx-timeout: 30ms
    [    0.994885] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16
    [    1.003499] arm-scmi arm-scmi.0.auto: SCMI RAW Mode initialized for instance 0
    [    1.010930] arm-scmi arm-scmi.0.auto: SCMI RAW Mode COEX enabled !
    [    1.017375] arm-scmi arm-scmi.0.auto: SCMI Notifications - Core Enabled.
    [    1.024286] arm-scmi arm-scmi.0.auto: SCMI Protocol v2.0 'TI:' Firmware version 0x0
    [    1.053593] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.063681] usbcore: registered new interface driver usbhid
    [    1.069473] usbhid: USB HID core driver
    [    1.074563] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    1.117136] random: crng init done
    [    1.122743] Initializing XFRM netlink socket
    [    1.128834] NET: Registered PF_PACKET protocol family
    [    1.134105] Key type dns_resolver registered
    [    1.147752] registered taskstats version 1
    [    1.152143] Loading compiled-in X.509 certificates
    [    1.214095] omap_i2c 2b200000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.221841] omap_i2c 20000000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.229846] pca953x 2-0022: supply vcc not found, using dummy regulator
    [    1.236911] pca953x 2-0022: using AI
    [    1.264892] pca953x 2-0023: supply vcc not found, using dummy regulator
    [    1.271879] pca953x 2-0023: using AI
    [    1.277933] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.287222] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.297204] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    1.306422] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.316811] omap_i2c 20010000.i2c: bus 2 rev0.12 at 100 kHz
    [    1.324444] /bus@f0000/i2c@20020000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    1.336618] omap_i2c 20020000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.344738] printk: legacy console [ttyS0] disabled
    [    1.350185] 2800000.serial: ttyS0 at MMIO 0x2800000 (irq = 282, base_baud = 3000000) is a 8250
    [    1.359084] printk: legacy console [ttyS0] enabled
    [    1.368780] printk: legacy bootconsole [ns16550a0] disabled
    [    1.394343] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 283, base_baud = 3000000) is a 8250
    [    1.407541] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.414549] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.419950] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.427005] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.433834] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.440746] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.447320] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.454511] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.461455] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.481714] spi-nand spi0.3: Winbond SPI NAND was found.
    [    1.487094] spi-nand spi0.3: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
    [    1.495760] 7 fixed-partitions partitions found on MTD device spi0.3
    [    1.502159] Creating 7 MTD partitions on "spi0.3":
    [    1.506956] 0x000000000000-0x000000080000 : "ospi_nand.tiboot3"
    [    1.514698] 0x000000080000-0x000000280000 : "ospi_nand.tispl"
    [    1.522952] 0x000000280000-0x000000680000 : "ospi_nand.u-boot"
    [    1.532666] 0x000000680000-0x0000006c0000 : "ospi_nand.env"
    [    1.539986] 0x0000006c0000-0x000000700000 : "ospi_nand.env.backup"
    [    1.547866] 0x000002000000-0x000007fe0000 : "ospi_nand.rootfs"
    [    1.605444] 0x000007fe0000-0x000008000000 : "ospi_nand.phypattern"
    [    1.626587] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA00103, cpsw version 0x6BA80103 Ports: 3 quirks:00000006
    [    1.639843] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    1.680290] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
    [    1.695244] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.703368] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.711632] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.718769] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    1.726795] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:200000000, add_val:4 pps:0
    [    1.745250] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 96
    [    1.755188] /bus@f0000/i2c@20020000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    1.767126] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/tps6598x@3f/connector
    [    1.783311] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
    [    1.788959] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
    [    1.796809] xhci-hcd xhci-hcd.4.auto: USB3 root hub has no ports
    [    1.802842] xhci-hcd xhci-hcd.4.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010
    [    1.812315] xhci-hcd xhci-hcd.4.auto: irq 297, io mem 0x31100000
    [    1.819377] hub 1-0:1.0: USB hub found
    [    1.823192] hub 1-0:1.0: 1 port detected
    [    1.831394] mmc0: CQHCI version 5.10
    [    1.832609] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    1.837729] mmc1: CQHCI version 5.10
    [    1.842787] clk: Disabling unused clocks
    [    1.854008] PM: genpd: Disabling unused power domains
    [    1.859329] ALSA device list:
    [    1.862472]   No soundcards found.
    [    1.884888] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.892471] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.900439] Waiting for root device PARTUUID=da7369e3-02...
    [    1.946750] mmc0: Command Queue Engine enabled
    [    1.951263] mmc0: new HS200 MMC card at address 0001
    [    1.957322] mmcblk0: mmc0:0001 0IM20E 29.6 GiB
    [    1.964139]  mmcblk0: p1 p2
    [    1.967838] mmcblk0boot0: mmc0:0001 0IM20E 31.5 MiB
    [    1.974141] mmcblk0boot1: mmc0:0001 0IM20E 31.5 MiB
    [    1.980510] mmcblk0rpmb: mmc0:0001 0IM20E 4.00 MiB, chardev (239:0)
    [    1.989109] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
    [    1.996738] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    2.006371]  mmcblk1: p1 p2
    [    2.567011] EXT4-fs (mmcblk1p2): recovery complete
    [    2.573106] EXT4-fs (mmcblk1p2): mounted filesystem 536b3021-c3ff-4bdf-a777-e547ff40735d r/w with ordered data mode. Quota mode: none.
    [    2.585301] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    2.595621] devtmpfs: mounted
    [    2.600040] Freeing unused kernel memory: 2752K
    [    2.604683] Run /sbin/init as init process
    [    2.821389] systemd[1]: System time before build time, advancing clock.
    [    2.871323] NET: Registered PF_INET6 protocol family
    [    2.877844] Segment Routing with IPv6
    [    2.881612] In-situ OAM (IOAM) with IPv6
    [    2.921402] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.953469] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2025.01!
    [    2.975126] systemd[1]: Hostname set to <am62lxx-evm>.
    [    3.617474] systemd[1]: Queued start job for default target Graphical Interface.
    [    3.664087] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    3.683255] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    3.703261] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    3.722640] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.740965] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    3.760905] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    3.780678] systemd[1]: Expecting device /dev/ttyS0...
    [    3.796719] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    3.812589] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.828596] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    3.844621] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    3.901500] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.920695] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.946574] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.965124] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.986200] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    4.005529] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    4.025578] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.045723] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.068683] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.085352] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.105435] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    4.149000] systemd[1]: Mounting Huge Pages File System...
    [    4.160548] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.193203] systemd[1]: Mounting Kernel Debug File System...
    [    4.213182] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    4.253468] systemd[1]: Mounting Temporary Directory /tmp...
    [    4.277462] systemd[1]: Starting Create List of Static Device Nodes...
    [    4.329541] systemd[1]: Starting Load Kernel Module configfs...
    [    4.354402] systemd[1]: Starting Load Kernel Module drm...
    [    4.397189] systemd[1]: Starting Load Kernel Module fuse...
    [    4.421256] fuse: init (API version 7.41)
    [    4.445575] systemd[1]: Starting Start psplash boot splash screen...
    [    4.491363] systemd[1]: Starting RPC Bind...
    [    4.509059] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    4.536968] systemd[1]: Starting Journal Service...
    [    4.585370] systemd[1]: Starting Load Kernel Modules...
    [    4.601516] systemd[1]: Starting Generate network units from Kernel command line...
    [    4.661115] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.667857] cryptodev: loading out-of-tree module taints kernel.
    [    4.680483] sysctl table check failed: ioctl/(null) procname is null
             Starting Remount Root and Kernel File Systems sysctl table check failed: ioctl/(null) No proc_handler
    [0m...
    [    4.704415] cryptodev: driver 1.14 loaded.
    [    4.721338] systemd[1]: Starting Coldplug All udev Devices...
    [    4.740103] systemd-journald[115]: Collecting audit messages is enabled.
    [    4.762407] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    4.781648] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    4.801623] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    4.833478] systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    [    4.857499] systemd[1]: Started Journal Service.
    [    4.863145] EXT4-fs (mmcblk1p2): re-mounted 536b3021-c3ff-4bdf-a777-e547ff40735d.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Start psplas�temd progress communication helper.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev gracefully...
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [    5.328935] systemd-journald[115]: Received client request to flush runtime journal.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
    [    5.656497] audit: type=1334 audit(1748544504.828:2): prog-id=6 op=LOAD
    [    5.668443] audit: type=1334 audit(1748544504.840:3): prog-id=7 op=LOAD
             Starting Rule-based Manager for Device Events and Files...
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save OS Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create System Files and Directories...
    [  OK  ] Finished Load/Save OS Random Seed.
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Finished Create System Files and Directories.
    [    6.007964] audit: type=1334 audit(1748544505.180:4): prog-id=8 op=LOAD
             Starting Network Name Resolution...
    [    6.041447] audit: type=1334 audit(1748544505.216:5): prog-id=9 op=LOAD
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [    6.128112] audit: type=1334 audit(1748544505.300:6): prog-id=10 op=LOAD
             Starting User Database Manager...
    [    6.140438] audit: type=1334 audit(1748544505.308:7): prog-id=11 op=LOAD
    [    6.153620] audit: type=1334 audit(1748544505.308:8): prog-id=12 op=LOAD
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started User Database Manager.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API...
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
    [    7.004428] audit: type=1334 audit(1748588073.032:9): prog-id=13 op=LOAD
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started Periodic Command Scheduler.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
    [  OK  ] Started Multiple Spanning Tree Protocol Daemon.
             Starting Telephony service...
             Starting Expand the rootfs partiti�to full size of the boot device....
    [    7.700767] audit: type=1334 audit(1748588073.732:10): prog-id=14 op=LOAD
    [    7.716402] audit: type=1334 audit(1748588073.740:11): prog-id=15 op=LOAD
             Starting User Login Management...
             Starting Telnet Server...
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Reached target Preparation for Network.
             Starting Network Configuration...
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Telephony service.
    [  OK  ] Finished Telnet Server.
    [    8.227066] Bluetooth: Core ver 2.22
    [    8.231029] NET: Registered PF_BLUETOOTH protocol family
    [    8.239470] Bluetooth: HCI device and connection manager initialized
    [    8.246030] Bluetooth: HCI socket layer initialized
    [    8.251071] Bluetooth: L2CAP socket layer initialized
    [    8.256387] Bluetooth: SCO socket layer initialized
    [  OK  ] Finished Expand the rootfs partition to full size of the boot device..
    [    8.960084] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [  OK  ] Started User Login Management.
    [    8.989305] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    9.001817] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [  OK  ] Started Network Configuration.
    [  OK  ] Reached target Network.
    [    9.290307] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    9.308998] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
             Starting containerd container runtime...
    [    9.390051] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [    9.411363] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
             Starting LLDP daemon...
    [  OK  ] Started Netperf Benchmark Server.
             Starting Simple Network Management Protocol (S[    9.503487] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    NMP) Daemon....
             Starting Wait for Network to be Configured...
             Starting Permit User Sessions...
    [    9.774581] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [  OK  ] Finished Permit User Sessions.
    [    9.917359] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [  OK  ] Started Getty on tty1.
    [    9.981907] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    [    9.993255] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [  OK  ] Started LLDP daemon.
    [   10.113896] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
    [   10.285391] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [  OK  ] Found device /dev/ttyS0.
    [  OK  ] Started Serial Getty on ttyS0.
    [  OK  ] Reached target Login Prompts.
    [   10.742593] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [   12.182460] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [   12.347635] at24 1-0051: supply vcc not found, using dummy regulator
    [   12.384015] at24 1-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write
    [   12.422318] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [   12.452459] tps6598x 3-003f: Unable to find the interrupt, switching to polling
    [   12.495615] dthev2 40800000.crypto: will run requests pump with realtime priority
    [  OK  ] Started containerd container runtime.
    [  OK  ] Reached target Hardware activated USB gadget.
    [   13.400082] input: tps65219-pwrbutton as /devices/platform/bus@f0000/bus@f0000:bus@43000000/2b200000.i2c/i2c-0/0-0030/tps65219-pwrbutton.3.auto/input/input1
    [   13.848968] sii902x 2-003b: supply iovcc not found, using dummy regulator
    [   13.860729] sii902x 2-003b: supply cvcc12 not found, using dummy regulator
    [   13.880689] i2c i2c-2: Added multiplexed i2c bus 4
    [   13.897092] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 0
    [   13.908014] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [   13.915981] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [  OK  ] Created slice Slice /system/tee-supplicant.
    [  OK  ] Started TEE Supplicant on teepriv0.
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Starting Virtual Console Setup...
    [  OK  ] Finished Virtual Console Setup.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am62lxx-evm ttyS0
    Arago 2025.01 am62lxx-evm ttyS0
    am62lxx-evm login: ***************************************************************
    NOTICE: This file system contains the following GPL-3.0 packages:
    	adwaita-icon-theme-symbolic
    	autoconf
    	bash-dev
    	bash
    	bc
    	binutils
    	cifs-utils
    	coreutils-stdbuf
    	coreutils
    	cpio
    	cpp-symlinks
    	cpp
    	dosfstools
    	elfutils-dev
    	elfutils
    	findutils
    	g++-symlinks
    	g++
    	gawk
    	gcc-symlinks
    	gcc
    	gdb
    	gdbserver
    	gettext
    	glmark2
    	gnu-config
    	grub-common
    	grub-editenv
    	grub-efi
    	gzip
    	hidapi
    	kbd-dev
    	kbd-keymaps-pi[   16.226919] rtc-ti-k3 2b1f0000.rtc: Configured RTC !
    ne
    	less
    	libasm1
    	libatomic-dev
    	libatomic1
    	libbfd
    	libd[   16.235658] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    ebuginfod1
    	libdw1
    	libelf1
    	libgcc-s-dev
    	libgcc1
    	libgdbm-compat4
    	libgdbm-dev
    	libgdbm6
    	libgettextlib
    	libgettextsrc
    	libgmp-dev
    	libgmp10
    	libgmpxx4
    	libgnutls-dev
    	libgnutls-openssl27
    	libgomp1
    	libidn2-0
    	libidn2-dev
    	libmpc3
    	libmpfr6
    	libopcodes
    	libreadline-dev
    	libreadline8
    	libstdc++-dev
    	libstdc++6
    	libtasn1-dev
    	libunistring-dev
    	libunistring5
    	m4
    	make
    	nettle-dev
    	nettle
    	parted
    	piglit
    	tar
    	which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    am62lxx-evm login: root
    [   26.715656] kauditd_printk_skb: 2 callbacks suppressed
    [   26.715674] audit: type=1006 audit(1748588092.744:14): pid=925 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
    [   26.734483] audit: type=1300 audit(1748588092.744:14): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffcc0ec678 a2=1 a3=1 items=0 ppid=1 pid=925 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   26.762189] audit: type=1327 audit(1748588092.744:14): proctitle="(systemd)"
    [   26.825218] audit: type=1334 audit(1748588092.856:15): prog-id=18 op=LOAD
    [   26.833301] audit: type=1300 audit(1748588092.856:15): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffd49670c8 a2=90 a3=0 items=0 ppid=1 pid=925 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   26.860227] audit: type=1327 audit(1748588092.856:15): proctitle="(systemd)"
    [   26.867334] audit: type=1334 audit(1748588092.856:16): prog-id=18 op=UNLOAD
    [   26.874428] audit: type=1300 audit(1748588092.856:16): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffbd0b83c0 items=0 ppid=1 pid=925 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   26.901212] audit: type=1327 audit(1748588092.856:16): proctitle="(systemd)"
    [   26.908441] audit: type=1334 audit(1748588092.856:17): prog-id=19 op=LOAD
    Linux am62lxx-evm 6.12.57-ti-g31b07ab8dfbc #1 SMP PREEMPT Thu Dec  4 13:07:37 UTC 2025 aarch64 GNU/Linux
    root@am62lxx-evm:~#
