Part Number: MSPM0G3507-Q1
In the SDK example timx_timer_mode_pwm_x_trig_stop_restore,
1) if TimerG is slave, phase shift is not available for TimerG
2) if TimerA is slave, the code in the main.c has to be commented out, otherwise the slave PWM won't be enabled. If the code in main.c is commented out, althogh phase load value can be set, it doesn't take effect.
What might be missed? Do you have a complete example to show how to set the sync and phase shift together?
Thanks!
Crane
