AM62L: AM62L Boot mode in Reduced Pincount BOOTMODE
Part Number: AM62L
Dear Team,
I have designed a SOM based on the AM62L32BOGHAANBR processor. Instead of using the recommended PMIC (TPS6521401VAFR), I used individual regulators for each power rail and ensured that the power-up sequence follows the required specifications.
However, I am facing a boot issue. The SOM does not boot from the microSD card during normal power-up. If I wait for around 5 seconds after powering on the SOM and then connect the debug cable, the SOM boots successfully. On the other hand, if the debug cable is connected before power-on and remains connected while the SOM is powered up, the SOM fails to boot.
Could you please help us understand the possible cause of this behavior and suggest how to resolve this issue ?
  • Hello Sujan,
    Could you please send me the WKUP_CTRL_MMR_CFG1_DEVSTAT register to see your boot media?
    Do you attach the debug cable to the JTAG USB?
    If the SD Card fails, does the UART starts and you see printing character "c" after each 2 seconds?
    When you replace the PMIC with discrete regulators, even if the rail sequencing order is correct, you likely don't have an equivalent power‑good supervisor generating PORz. This means PORz may release too early (before all rails have fully settled/margined), or PORz may have a noisy/glitchy edge (e.g., a simple RC-based reset instead of a monitored one). Either of these can cause the boot ROM to mis-sample the SYSBOOT pins or start executing before the rails (especially VDD_CORE/VDDSHV) are truly stable — leading to a failed SD boot.
    By this time, all your rails are already stable. When the debug probe attaches, it typically asserts and then releases the device's reset as part of its connect sequence. Since this reset release now happens after rails are fully settled, PORz is effectively "redone" cleanly, and the SYSBOOT pins get sampled correctly — so it boots.
    What you can do:
    Borislav Lazarkov
