MSPM0C1106: Timer PWM capture
Part Number: MSPM0C1106
I am using the Timer Capture feature on the MSPM0C1106 to detect an incoming PWM signal.
Could you please confirm the exact voltage thresholds required for the pin to register a high or low edge? For a standard 3.3V supply, what are the minimum  and maximum voltage levels?
Additionally, does the Timer Capture trigger a "High Edge" immediately when the pin voltage crosses the digital high threshold?
    For exact thresholds please see our datasheet GPIO chapter.
    Please see our user guide: https://www.ti.com/lit/pdf/slau893 Timer chapter
    It will cause ~3 cycles for sync when you disable Filter.
    Zoey
