TMS570LC4357: Query Regarding Functional Safety Support for TI Compilers for Hercules MCUs
Part Number: TMS570LC4357
Hi TI Team,
We are currently using TI Compiler v18.12.2.LTS with Code Composer Studio for software development on the TMS570LC43xx Hercules MCU.
We would like to clarify the following:
  1. Does TI Compiler v18.12.2.LTS have any functional safety qualification, certification, or assessment?
  2. Is there any Tool Qualification Kit (TQK), Safety Manual, Compliance Support Package, or other functional safety documentation available for this compiler?
  3. Has this compiler been developed, assessed, or qualified for use under standards such as IEC 61508, ISO 26262, or EN 50128?
  4. Does TI provide any other compiler or compiler version for Hercules MCUs that includes functional safety qualification or supporting safety documentation? If yes, could you please provide the relevant details?
  5. If such documentation is available, could you please share the relevant documents or provide links?
Thank you for your support.
Mohamed Asheeq
  • Hi Mohamed Asheeq,
    TI provides Compiler Qualification KITs to enable customers to use TI compilers for functional safety development.
    Please download the CQKIT first:
    https://www.ti.com/tool/SAFETI_CQKIT
    Also please refer below presentation link once, here you will understand the procedure to apply qualification kit:
    How to apply the TI Compiler Qualification Kit for functional safety development
    Thanks & regards,
    Jagadish.
  • Hi Jagadish,
    Thank you for sharing the CQKIT details.
    We are preparing the compiler qualification document for our customer, and I have one clarification.
    From the documents, I understand that the SafeTI Compiler Qualification Kit has been assessed by TÜV. Does this assessment also apply to the TI ARM C/C++ Compiler (20.2.x LTS), or only to the Qualification Kit?
    For our customer documentation, what is the correct statement to use?
    • The TI ARM C/C++ Compiler is qualified using the TÜV-assessed SafeTI Compiler Qualification Kit.
    • Or, the TI ARM C/C++ Compiler is TÜV certified/assessed.
    If there is an official document or certificate that clarifies this, could you please share it?
    Thank you.
  • Hi Mohamed,
    SafeTI Compiler Qualification Kit (CQK) - TUV assessed (the process/kit)
    TI ARM C/C++ Compiler (20.2.x LTS) itself - Not TUV certified/assessed directly
    • TUV reviewed that the CQK provides an adequate process to qualify the compiler for use in safety-critical applications
    • The compiler itself undergoes qualification by the end-user/integrator using that TUV-assessed kit
    Thanks & regards,
    Jagadish.
