AM263P4-Q1: SAFETY_ERRORN-D4 ball name
Part Number: AM263P4-Q1
Other Parts Discussed in Thread: AM263P4
Hi Team
  • Is there any fault signal between the MCU to PMIC to indicate a fault condition?
  • Please explain the functionality of the SAFETY_ERRORN pin (D4). What is its normal logic state (HIGH/LOW), and under what conditions does it change state? Please also explain the fault-detection mechanism and signal behavior of this pin.
  • Hi Venkata Rami Reddy,
    Yes, there is a dedicated fault signaling mechanism between the AM263P4 MCU and the PMIC. The primary signal used for this purpose is "SAFETY_ERRORN". SAFETY_ERRORN is an active-LOW error/fault indicator from the MCU to the PMIC.
    The MCU asserts SAFETY_ERRORN LOW to inform the PMIC (e.g., TPS6594x family) that a safety-critical fault has been detected internally, allowing the PMIC to take protective action (rail shutdown, reset, etc.).
    The Error Pin Output is active low or PWM, based on the Error Pin Control register pwm_en field.
    Many customers will select active low by default and here is its operation in this mode:
    Normal Operation → SAFETY_ERRORN = HIGH (de-asserted)
    Fault Condition → SAFETY_ERRORN = LOW (asserted)
    Each Error Event Input can be programmed, via software, to influence the Error Pin Output.
    Up to 111 (64 level events + 47 pulse events) error event inputs are there. You can find this list in TRM section "10.4.6 ESM0 Interrupt Map".
    Here 111 ESM events are listed down, and we can route any number of these inputs to drive SAFETY_ERRORN pin.
    Thanks & regards,
    Jagadish.
  • 1.Does SAFETY_ERRORN being LOW mean that the PMIC will completely power off?
    2.Is SAFETY_ERRORN associated with the safety system?
  • Apologies, The expert is out of office today. Please expect a response by Tuesday
    Apologies for the delayed response!
    When SAFETY_ERRORN asserts LOW, the PMIC response is configurable and does not always mean complete power off.
    SAFETY_ERRORN = LOW
    PMIC evaluates configured response
    • Most Common: SoC RESET (rails stay powered) -> MCU reboots and re-initializes
    • Safety-Critical Systems: Power Rail Shutdown + Reset -> Full power cycle before restart
    • Complete Shutdown (rare, specific safety configs) -> Manual power cycle required
    Yes, it is part of safety system.
    All important safety mechanisms errors like lock-step, ECC errors on memories, LBIST/PBIST, watchdog, bus safety parity etc are aggregated by ESM module and this ESM module will trigger the SAFETY_ERRORN pin to let external world that some error in these safety mechanisms.
    Thanks & regards,
    Jagadish.
