Part Number: AM263P2
Other Parts Discussed in Thread: XDS110ISO-EVM, LP-XDS110
Hi Team
Hi Team
Hi Venkata,
I see you're getting Error -260 when trying to connect your XDS110 debugger to the AM263P2. The error message points to several possible causes, and the fact that your MCU is functioning and voltages check out is good—this looks like a debugger communication issue rather than a hardware fault.
Just to confirm, are you using a TI EVM or is this custom hardware?
Here's what I'd recommend checking:
USB connection & cable – Verify the USB cable is firmly seated on both ends and try a different USB port (preferably a direct port on your computer, not a hub). A faulty or loose cable is a common culprit.
XDS110 firmware & serial number – As the error suggests, run the firmware update utility:
<CCS_install>/ccs_base/common/uscif/xds110/xdsdfu utility to check and update the firmware and serial numberDebugger LED status – The LED being off is unusual. After updating firmware, check if the LED comes back on. This would indicate the debugger wasn't being recognized by your system.
Zackary Fleenor
LP-AM263P2 TI EVK board and cable is verified
I will update the 2nd step XDS110 firmware &serial number
