Part Number: AM62A7
Other Parts Discussed in Thread: SK-AM62A-LP, , SYSCONFIG, PROCESSOR-SDK-AM62A
Dear Sir,
We are currently developing a custom hardware platform based on the AM62A74 SoC. The hardware has been designed with reference to the TI evaluation kit and according to our system architecture.
We have received the fabricated boards and initially we were able to successfully download the firmware, boot the system, and run the application as expected.
However, we are now facing an intermittent boot issue on some of the boards. We are observing unexpected kernel panics during the boot process, while some other boards with the same hardware design and software image are working normally.
The issue is intermittent and difficult for us to identify the root cause. We would appreciate your support in analyzing this issue.
We would specifically like your guidance on the following:
- Could this issue be related to the software image, Linux kernel version, U-Boot version, or other software components?
- Could you please review the attached boot/kernel panic logs and help us identify the possible root cause?
- Could this behavior be related to DDR initialization, memory timing, power sequencing, or hardware-level variations?
- Are there any specific AM62A74 hardware checks, boot logs, debug registers, or diagnostic procedures that you recommend for troubleshooting intermittent kernel panics?
- Is there any recommended TI software release, SDK version, kernel version, or bootloader version that we should use for our custom AM62A74 board?
- Since some boards are working correctly while others are experiencing the issue, could you please advise us on the best way to distinguish between a hardware issue and a software/image-related issue?older_boot_with_latest_kernel_2.txt
We have attached the relevant kernel panic and boot logs for your reference.
Could you please analyze the logs and provide your recommendations on the possible root cause and the next steps for debugging?
Your support in resolving this issue would be highly appreciated.
Samudralankaiah
