MSPM0L2228: SHUTDOWN mode current when VBAT is tied to VDD
Part Number: MSPM0L2228
Hi expert,
I am evaluating MSPM0L2228 and would like to clarify the power consumption in SHUTDOWN mode when RTC is used.
From the datasheet, I understand:
  • SHUTDOWN current = 80 nA (VDD)
  • VBAT current = 1.1 µA with 32 kHz, LFXT, RTC, and I/O wake-up
My application does not use a separate backup battery. The VBAT pin is connected directly to VDD (single battery system).
Could you please clarify the following?
  1. When VBAT is tied to VDD and RTC is running in SHUTDOWN mode, what is the expected total supply current from the battery?
  2. Can the 80 nA (VDD) and 1.1 µA (VBAT) values be directly added together?
  3. Is there any measured data showing the current consumption of:
    • SHUTDOWN + RTC
    • VBAT connected to VDD
    • LFXT enabled
  4. For a battery-powered instrument that requires:
    • RTC running
    • GPIO wake-up by push button
    • no separate backup battery
    would TI recommend SHUTDOWN mode or STANDBY mode?
Best regard,
Ibuki Endo
    When VBAT is tied to VDD, the total current drawn from the battery is the sum of the current consumed by the VBAT Island and the VDD Island (SoC). As shown in the STANDBY mode table,
    If your priority is absolute minimum current and your application can handle a full system reset upon wake-up, choose SHUTDOWN. If your priority is responsiveness and state retention, choose STANDBY.
