Part Number: AM2611-Q1
Other Parts Discussed in Thread: AM2611,
I am designing with the AM2611 in the ZEJ package which makes the AM2611-Q1 an option.
My system already requires a 1.2V supply for another part on the board. I would prefer to power the AM2611 VCC at 1.2V even if I need to run at 400MHz instead of 500MHz. This saves the addition of another power supply rail on the board.
The data sheet specifically says "Devices of the 'O' Speed grade must follow the Recommended Operating Conditions for R5F at 500MHz regardless of the core frequency settings". I find that only the 'O' speed grade is currently available.
Does this mean I need to purchase the AM2611-Q1 if I want to run VCC at 1.2V?
I guess my other option is to split the difference and run both parts from a single 1.22V supply. That is inside the limits of both parts, but removed some margin.
