Part Number: AM263P4
Other Parts Discussed in Thread: SYSCONFIG,
Hello TI Team,
I am using the sbl_ospi_multicore_elf example on an AM263Px device and noticed that the SBL performs clock initialization through functions such as:
The generated Bootloader_socConfigurePll() function configures the Core and Peripheral PLLs with hard-coded frequencies (for example, 400 MHz, 500 MHz, 160 MHz, and 192 MHz). However, I am unable to find any corresponding PLL or clock frequency settings exposed in the SBL SysConfig GUI.
Could you please clarify:
- What is the source of these PLL frequency values?
- Are these frequencies generated from hidden/default SysConfig settings, or are they fixed by the SBL template implementation?
- What is the recommended method to modify the Core PLL and Peripheral PLL frequencies for a custom application?
- If modifications are required, should they be made in the generated source file, SysConfig template, or some other configuration file?
- Are there any application notes or guidelines describing the clock initialization flow used by the AM263Px SBL?
Our goal is to understand how the SBL configures the device clock tree and determine the supported method for customizing PLL frequencies while maintaining compatibility with the SDK boot flow.
Thank you for your support.
Gokul
