Part Number: TPS3851-Q1
Other Parts Discussed in Thread: TPS3851
We are using the TPS3851G33SQDRBRQ1 watchdog in our design.
Issue observed:
We are providing the WDI input using a signal generator with a period of approximately 323 ms. With this input, we observe that the WDO output is continuously toggling. However, when the WDI input is stopped, WDO does not remain low as expected.
Could you please help us understand the expected WDO behavior in this condition?
Also, we would like to implement the same watchdog functionality using software. Could you please advise:
What watchdog timeout configuration should be used for a 323 ms WDI period?
How should the WDI signal be generated from the MCU software?
Is there any software configuration required to make WDO assert low when the MCU stops generating the WDI signal?
Since the TPS3851-Q1 uses the CWD/SET1 hardware configuration for the watchdog timeout, please confirm whether there is any software-configurable option available for this device.
Please suggest the recommended configuration and timing sequence for our application.
