image processing using Hercules
 I am new to Hercules and would like to know if its possible to perform image processing using these microcontrollers ?
Vivek
  • Hi Vivek,
    Please excuse us for the delay in answering your post.
    The Hercules microcontrollers implement the highest-performance ARM CPU among TI microcontrollers. This processor is also coupled with a floating-point unit allowing you to execute several computational algorithms on the FPU while simultaneously integer code on the main instruction pipeline.
    Please look into the DMM (Data Modification Module) interface on the Hercules microcontrollers for interfacing to an external CMOS imager module. You may still have to place some additional components on the PCB before you are able to utilize the DMM for image capture, but this is the best-suited interface on the Hercules microcontrollers.
    Regards, Sunil
