Part Number: MSPM0L2227
I want to program my MSPM0L222x series controller using BSL via USB-UART bridge like CH340. I actived BSL bootloader but how to connect it with CH340.
Hi Pritam,
Assuming the CH340 has a UART TX and RX pin, you should connect it to the designated Default BSL UART pins i.e. for this device is PA10 and PA11), and ground together. From there, you can use the following documentation to program the device through BSL:
2. MSPM0 Bootloader Implementation
Diego Abad
