Part Number: AM2612
Could you tell me how to configure OSPI in Tap DDR mode?
OSPI_RD_DATA_CAPTURE_REG[DELAY_FLD] is used to delay the timing of data capture during a read operation from OSPI_CLK output by DELAY_FLD × ref_clk cycles,is that correct?
OSPI_RD_DATA_CAPTURE_REG[DDR_READ_DELAY_FLD] is used to delay the timing of data output during a write operation from OSPI_CLK output by DDR_READ_DELAY_FLD × ref_clk cycles,is that correct?
OSPI_RD_DATA_CAPTURE_REG[DDR_READ_DELAY_FLD] is described in the Register Addendum as follows.
"DDR read delay: Delay the transmitted data by the programmed number of ref_clk cycles.This field is only relevant when DDR Read Command is executed. Otherwise can be ignored."
Is OSPI_RD_DATA_CAPTURE_REG[DDR_READ_DELAY_FLD] used only when a DDR read command is issued, rather than during a write operation?
If so, how is the delay of the timing of data output during a write operation configured?
What is OSPI_RD_DATA_CAPTURE_REG[SAMPLE_EDGE_SEL_FLD] used for?
Does it configure the active edge in Tap SDR mode? Is it used for Tap DDR mode?
Daisuke
