Hi
Have one LM4F EVK, wondering if two instances of KEIL IDE can be running at the same time?
-Hailin
Hi
-Hailin
Hailin Jiang said:Have one LM4F EVK, wondering if two instances of KEIL IDE can be running at the same time?
For what purpose? Is this in any way related to your other post about migrating projects from a LM3S to LM4F?
In general, if your questions are related to a particular IDE, like Keil, then the Keil support team would be more appropriate. But depending on your answer to the "purpose" question, this may be a good spot for discussion.
It is easy to debug if two instance of IDE on one PC is running simultaneously. According to KEIL support, two-ULINK is possible. My specific question is if two ICDI are possible? ICDI should use the device driver from TI. That is why I am asking the question here.
Thank you,
-Hailin
