Other Parts Discussed in Thread: NOWECC
Hello Support,
In the attached Test_ECC.zip file, you will find Cortex_F021_ECC.pdf file describing the issue.
When I perform offline calculation with spna126.pdf given Boolean Equation, the value obtained doesn't match with nowECC output.
I am using 16M_NOADD option for nowECC.
testecc.bat contains the command I used for generating the output file.
Please help.
Thank you.
Pashan
