LM4F232: How Can I get a frequency out of 1.8432 MHz ? What should be the cpu frequency for this ?
Agree w/poster Markel - "if" he's guessed correctly regarding just what you're asking. (your question is unclear)
Should you - instead - seek to have the MCU generate a 1.8432 MHz output signal - the old stand-by would be to select an integer multiple of this 1.8 MHz frequency for your MCU's main oscillator xtal. Readily available - valid xtals include: 7.3728 & 14.7456. Higher frequencies may run afoul of the MCU's upper frequency, xtal limit. (your datasheet will detail)
After choosing/installing the proper xtal - use of one of the many timers of the M4F can output your desired frequency (and many others - should you desire) onto your choice of GPIO pin - under timer-interrupt control. (simply toggle that GPIO w/in your short timer interrupt routine)
