Other Parts Discussed in Thread: HALCOGEN
When using the IDE or Halogen to program the HET do these tools produce assembly that is then linked into my main code? Does/can it generate C instead?
Also there are function calls and libraries that I can use to do some basic capture and compare or PWM outputs. Are the libraries in C or are they in assembly - is each function described along with source code somewhere?
Calum
