TMS570 C Header Files
Other Parts Discussed in Thread: HALCOGEN
Hi there,
My name is Brent from MDA. Could you show me the TMS570 C header files for the name definition of the device registers? I just want to know how these names are defined in C and how to refer to these names in my C program. Because I will use TMS570 in the upcoming project and I'm new in uC programming.
Thanks a lot,
Brent Shen
  • Brent,
    I assume that you are looking for the header file for system and peripheral modules registers. We have one header for each module. I am attaching one for the DMA module here. See if it is what you are looking for.
    7065.dma.h
    I would suggest you installing TI Halcogen tool. It will help you to start.
    Thanks and regards,
    Zhaohong
  • Hi Zhaohong,
    Thanks a lot for the info above. After checking the sample header file (7065.dma.h) for DMA module, I found a struct called DMA_ST which defines all the DMA registers using their offset address. If I declare a pointer to DMA_ST, can I assign the starting addressing of the MDA module (0xFFFFF000) to the pointer in order to reference its individual registers? For example,
    DMA_ST * p = 0xFFFFF000;
    p->GCTRL_UN.GCTRL_ST.DMA_EN = 1;
    Thanks again,
    Brent Shen
  • Brent,
    If you use TI compiler, you need to put a cast to the physical address as follows.
    DMA_ST * p = (DAM_ST *)0xFFFFF000;
    The rest of your code should work.
    Thanks and regards,
    Zhaohong
