Other Parts Discussed in Thread: TMS570LS20216, HALCOGEN
Hi Everyone,
I've connected a 64Mbit NOR flash to the EMIF (using CS0), this device needs to be programmed before any data can be written to its addresses, looking at the data sheet and TMR the EMIF should be able to handle this via the use of specially written functions.
However I need to be sure the TMS570 will not try and access this address range in any of its background routines (or as a result of array generation from my code) as data can not be stored at these addresses with out preparing the NOR flash.
Can you confirm that the TMS570 will not try and do this or alternatively indicate how the TMS570 can be set up to have this address range protected or access restricted?
Thanks in advance
Alex
