Hello. You could advise a method of implementation of output of PWM of a signal from the N2HET module. Thus that start would be carried out from the main program, the given quantity of the periods of PWM stood out (for example 10), further stopped, before receiving the following signal of start. What command it is possible to pause and launch N2HET if the controler works in Functional mode (nTRST signal = 0)
