DMA problem
After enabling DMA the corresponding bit in the CNTRL register remains zero  (DMA disabled)
What clock drives the DMA ?  I double checked my Clock mappinh and all clocks are enables
Any ideas ?
  • Hello Greg,
    I have received your question and I am looking into it. I should have an answer for you early next week.
  • Hello Greg,
    When you elaborate on what steps you have taken to enable DMA? The 2 bits that you should be particularly interested in are the DMA_EN bit and the DMA_RES bit. DMA_RES should be 0 and then DMA should be enabled once you write a 1 to DMA_EN. If. If these are the steps you have taken, you may want to try forcing a DMA reset by writing DMA_RES from 0-->1 then back to 0. After reseting the module, then write a 1 to DMA_EN.
    If all of  your clock domains are enabled, this should not be a concern.
