Issues with Stellaris M4F PinMux Utility 1.0.1
Other Parts Discussed in Thread: TM4C123GH6PM
I found found some issues in the code generated by the PinMux Utility.
1. The code for the SCL pin on the I2C port generated is:
    MAP_GPIOPinConfigure(GPIO_PB2_I2C0SCL);
    MAP_GPIOPinTypeI2CSCL(GPIO_PORTB_BASE, GPIO_PIN_2);
It should be:
as Stellarisware does not map the GPIOPinTypeI2CSL to ROM
2. USB code generated is:
    // Enable port PL7 for USB0 USB0DM
    MAP_GPIOPinConfigure(GPIO_PL7_USB0DM);
    MAP_GPIOPinTypeUSBAnalog(GPIO_PORTL_BASE, GPIO_PIN_7);
    // Enable port PB0 for USB0 USB0ID
    MAP_GPIOPinConfigure(GPIO_PB0_USB0ID);
    MAP_GPIOPinTypeUSBAnalog(GPIO_PORTB_BASE, GPIO_PIN_0);
    // Enable port PB1 for USB0 USB0VBUS
    MAP_GPIOPinConfigure(GPIO_PB1_USB0VBUS);
    MAP_GPIOPinTypeUSBAnalog(GPIO_PORTB_BASE, GPIO_PIN_1);
    // Enable port PL6 for USB0 USB0DP
    MAP_GPIOPinConfigure(GPIO_PL6_USB0DP);
    MAP_GPIOPinTypeUSBAnalog(GPIO_PORTL_BASE, GPIO_PIN_6);
Should be:
As GPIO_PL7_USB0DM,GPIO_PB0_USB0ID,GPIO_PB1_USB0VBUS,GPIO_PL6_USB0DP are not valid defines because they are never referenced in code.
