Other Parts Discussed in Thread: HALCOGEN
http://www.ti.com/tool/halcogen
The zip file still contains 3.01.0.1.
Davor,
I just did a download of HalCogen, and the version is 3.02.02
You may have to refresh your page before doing the download.
Where exactly did you download from?
I used this:
http://www.ti.com/lit/sw/spnc030/spnc030.zip
And it still contains the old files.
Additionally, when updating from withing Halcogen, I get this:
Davor,
I'm using the same link.
It is certainly a browser cache problem.
Here is the zip file 1007.spnc030.zip
What is the actual version of Halcogen you have installed on your system.
I've tried an update, and apparently there is a problem.
I will investigate and let you know.
Davor,
The Halcogen update should now work.
There was a problem on our server this morning. It has been fixed.
If you have not yet installed 3.02.02, you should be able to update your 3.01.01 from HalCogen Help-Check Update.
Davor,
The best way for now is to use this forum.
If you have bugs or enhancement request, please create a new forum question for each.
That way it will be easier to do a follow-up.
