I got the bootloader code running in RM48. I wanted to download the application code into RM48 flash using the PC-side VC++ example Host Application Software provided by TI (CAN_Bootloader_Test.zip at http://processors.wiki.ti.com/index.php/RM48_HDK_Kit#HDK_BootLoader_Sample_Code).
However, when I tried to run it, it gave me the following error message:
"The program can't start because NICAN.dll is missing from your computer. Try reinstalling the program to fix this problem"
I would like to know where I can get this DLL.
Could you please provide a procedure on how to correctly setup the sample application software so it can download the application code into RM48? The UART example has a detailed procedure on how to do it.
Dennis
