Hello Support,
In the TRM spnu515.pdf, attached paragraph looks incomplete. Can you please send me the complete document for the missing paragraph?
Thank you.
Pashan
Hello Support,
Thank you.
Pashan
This paragraph has been corrected in the source and will read as follows on the next update of this document:
"As the device is coming out of the device reset sequence the flash wrapper reads two configuration words from the TI OTP section of bank zero, the hardware configuration word at address 0xF0080140 and then the AJSM visible password at addres 0xF0000000. During these reads ECC is enabled. Single bit errors are corrected. Uncorrectable errors will generate an ESM group 3 channel 7 error event and the ERROR pin will be activated."
