Other Parts Discussed in Thread: HALCOGEN
I am trying to get a basic HalcoGen App to run using IAR IDE. The code seems to get stuck in mapClocks(). The same setting for HaloGen worked fine in CCS.
/* Work Around for Errata SYS#46:
* Errata Description:
* Clock Source Switching Not Qualified with Clock Source Enable And Clock Source Valid
* Workaround:
* Always check the CSDIS register to make sure the clock source is turned on and check
* the CSVSTAT register to make sure the clock source is valid. Then write to GHVSRC to switch the clock.
/** - Wait for until clocks are locked */
while ((systemREG1->CSVSTAT & ((systemREG1->CSDIS ^ 0xFFU) & 0xFFU)) != ((systemREG1->CSDIS ^ 0xFFU) & 0xFFU))
} /* Wait */
