Other Parts Discussed in Thread: TMS570LS1227
Does it support TMS570LS1227? I couldn't find it from "HET Device Configuration"
Hello Jun,
You can choose the TMS570LS31xx device for your project. The N2HET module on this device has the same feature set as the N2HET module on the TMS570LS1227.
I will also check with the HET IDE development team to also include the LS1227 in the list of supported devices.
Regards, Sunil
Hi Jun,
Please confirm that you are using the latest version of the NHET IDE utlity. I followed the instructions in http://www.ti.com/lit/an/spraba0b/spraba0b.pdf and got the selected device showing up in the project properties.
You can also manually set the device used by right-clicking on the project name in the "Project Explorer". Can you try if you can set the device to be used using this method?
Regards, Sunil
Jun,
I see the device name as well as the N2HET module registers when I just open the project that you attached. See attached.
I would recommend uninstalling and re-installing the HET IDE. Also remember to right-click on the .exe file and choose to "Run as Administrator".
Regards, Sunil
Hi Sunil,
I followed your recommendation, uninstalled the HET IDE, re-installed it by right click .exe and "Run as Administrator". Then I try to creat a project as described in my first post. In the Output window I have
Connected to Simulator
Starting the simulator ....
Constructed frontend interface 1 ...
and stuck. Again no device no registers shown up.
Please help.
Jun
