The definition of STC Test Coverage
Guru 16800 points
In page 338 (8.3) of TRM (spnu499), "Table 8-1. STC Test Coverage and Duration" is described.
What STC Test Coverage mean?
I want to know the numerator and the denominator for the coverage.
Also, could you teach me the detected faults by STC Test?
For example, in case of March13N, Address decoder faults, Stuck-At faults, Coupled faults and so on are detected, which is described in p.318 ("7.4 Memory Test Algorithms on the On-chip ROM").
I need the same information for LBIST.
Nomoto
  • Hello Nomoto,
    I have forwarded your question to the expert on this.  They will be responding soon.
  • Nemoto,
    The coverage nos shown in the TRM are traditional stuck-At Fault test coverage numbers generated by automatic test pattern tools.This  for pure digital logic which is the case for the CPU. Let me know if you need more information.
    Hercules forum support
    •The definition of Test Coverage:
                 Test Coverage = Detected Faults / Detectable Faults
                                                         DT + (PT x PT_Credit)
                                          =   ----------------------------------------- x 100
                                                            All Faults – UD
    •DT refers to Detected Faults which are further classified as below
        –DS : Detected by simulation.  Determined by generating patterns.
        –DI : Detected by implication. Determined by shifting the scan chains.
    •PT refers to Possibly Detected faults these  Faults for which the difference b/w the good machine and faulty machine results in simulated output of X rather than 1 or 0.
     PT_credit refers the credit we give to possibly detected faults in our case we give a credit of zero the most pessimistic scenario.
    •UD refers to undetectable faults : Faults cannot be detected by any means. Like Unused f  ,Tied  ,Blocked  and Redundant faults
