Other Parts Discussed in Thread: TL7700
Hi all,
I'm using TPS65381 to control a TM570LS31337.
In case of WD_FAILURE and MCU_ERROR, I need to force the device in permanent STANDBY STATE (no restart). Is it possible ? In the affirmative, how ?
I 'm able to make the device enter the STANDBY state (from SAFE state) but it restarts because IGN pin is high.
NB: In my application CANWU pin is not connected and IGN pin is connected to a TL7700 voltage monitor with the only purpose to keep IGN pin low on start up. Due to this, I cannot use this pin to force a shut down.
Thank you for your advice.
