Lisa TI said:Hi Dorijan,
I have followed the instructions here (have you as well? Did you install the rxtx package?) and have no problem with the terminal. As seen in the attached screenshot I can open the settings. On the bottom right the green or yllow buttons on the terminal window should open settings for you,
http://processors.wiki.ti.com/index.php/How_to_install_the_terminal_plugin_in_CCSv5
Please let me know if this helps.
Lisa
I am using CCS v5.3 with LM4F120H5QR... I am using terminal (I've installed the terminal plugin - it was in it by default)
when I connect my device it works properly for 1 or 2 sec. then it stops!!
No errors and without creating any problems it just stop displaying the data.
I want to read data continuously. What should I do for that??
Thanks for your help.
