HalCoGen does not generate correct SDRAM-setup
Other Parts Discussed in Thread: RM48L952, HALCOGEN
We are in progress of making our own board with an RM48L952 MCU.
During the work of getting the SDRAM to work, I just discovered that after having typed in the timing parameters for the SDRAM, the code generated in emif_SDRAMInit
does not change if I only changes the PLL1 frequency (and thereby the clock for the EMIF module).
The counts stays the same unless I just look at the EMIF-tab.
I suppose this is not intentional!
Best regards
   Michael c".)
  • Hi Michael,
    Sorry for the inconvenience caused, It's a bug in HALCoGen. Will inform the developer to fix this in upcoming release.
    Until then please make sure PLL settings are carried before setting EMIF.
    Prathap
