I'm trying to scope the CAN0TX signal on an oscilloscope to view a CAN message. I get an output, but it doesn't reflect our expected output.
I'm using the EKS-LM4F232 Evaluation Kit and using the simple_tx.c example given in Stellarisware.
Is it possible to actually view the signal without connecting to a transceiver? I want to see the start of frame, identifier, rtr fields..etc.
I have the CAN0RX connected to 3.3v to get the output I have. This was suggested by another member on this forum.
The only thing I can do to modify the output is change the bitrate. Changing the data does nothing.
Here's the pattern I'm getting.
