Tiva ARm processors
Hi Just curious if there is any update available for CCS5 to support Tiva C series ARM micros ?
  • Hello Harish,
    As of now, there is no new version CCS.
    But you can use the current version CCS to do your work on Tiva C series products,
    the Tiva C series products are identical to Stellaris LM4F23x series.
    The new datasheets will tell you which Stellaris and Tiva C products are the same on the first page.
    e.g.,
    http://www.ti.com/lit/ds/spms372/spms372.pdf
    In the future, we do have a new version CCS for Tiva.
    Jo
  • Jo Chen said:
    The new datasheets will tell you which Stellaris and Tiva C products are the same in the first page.
    Thanks for this - appreciated.
    However - placing such data w/in each/every MCU datasheet (even on the first page) seems far from optimal!  Does this not force your valued users to waste much time/effort - in the attempt to find a, "match?"  How do we know which datasheet to open?  (there are many!)
    Clearly a well placed (i.e. easy to find - properly announced) "MCU Cross Reference Sheet" would be far more comfortable - and efficient for your, "valued users."
    "Comfort & Convenience" have long proved trustworthy & efficient cohorts - when building Sales.  Suspect the existing ID method you've just described misses badly - on both counts...
  • Hi cb1 and all,
    Please see this document to quickly find the new Tiva part number for your existing LM4F part.  We are also working on a web app that allows you to enter your part number and return the new one.
    Sue
  • Thanks Sue,  it was not easy to find this answer by searching TI website.
    Thanks Again.
    Harish
  • Hi Sue,
    Thanks your usual efficiency and kindness.  Your description of such a web app is, "above/beyond" our hopes/expectations - surely will be appreciated by all...
