Other Parts Discussed in Thread: HALCOGEN
I'm trying to startup woth ethernet on the Herculed HDK (TMDX570LS31HDK).
I've found these two documents:
http://www.youtube.com/watch?v=GVoOsDfwPY4
http://processors.wiki.ti.com/index.php/HALCoGen_Ethernet_Driver_and_lwIP_Integration_Demonstration
but both of them referred to a downlodable application that do a lot (and does not work on CCSv4).
There isn't a simple code sequence to setup a send/receive on the ethernet (like an echo service) that does not involved a lot of other function?
For example a code snippet to implements the "Programming Sequence using HALCoGen generated drivers" on the above wiki page.
Thank you.
