How can I pass data to interrupt handlers for Stellaris Launchpad?
Hello Everyone,
I want to create a small new protocol in order to communicate with other non TI MCU's (though I rather used TIMCUs, but don' have any around so...) so had a look on the timers example found under /StellarisWare/boards/timer
I understood the fact that interrupt handlers are in a way independent code snippets that are processed when an interrupt occurs. The thing is that I would like to send some data from inside main() or an other function to such handler functions.
Thank you in advance for your time and examples.
Costin
    Well, let's say the things are a little bit opposite to your point of view: you must think to peripherals as hardware add-on to a cpu, in order to signal hardware events to be taken int consideration by the cpu. This is done with interrupts. From interrupts you can read global data or call any global function - but the reverse - i.e sending data from main to interrupts can be done by triggering an interrupt - not so easy (although can be done) in the presence of real events.
    I recommend you to look at this site - there are very good examples there - in fact it would be better to run/understand everything which can be downloaded from this site (if you can afford it, buy the manual).
    Petrei.
    PS: are you the same on stelarisiti?
