Hello Support,
As mentioned in spnu517.pdf TRM, EFCPINS will read as ZERO for the LSB 10 bits of DATA.
But I am getting as 0x2E0.
Please help about the discrepancy.
Thank you.
Pashan
Hello Support,
Thank you.
Pashan
Hello Support,
Please reply with some answer to this e2e question.
Thank you.
Pashan
Pashan,
I apologize for the delay in response. It looks like this thread slipped through the cracks. Please stay posted for a response to your original question.
- Forum support
Hello Pashan,
I have read the same value on my bench system and I highly expect this to be a documentation issue only. To be certain, I am discussing this with another member of the apps team that has more history with the eFuse IP. I will ping him to see if he has had an opportunity to look into this further.
Hello Pashan,
I have confirmed that this is an error in the definition of the EFCPINS register bits9:0. The correct information would be R-x below the bits in the register diagram and read values can be either a 1 or 0 in the bit field description table. I have submitted a document feedback/bug for this so that it can be corrected in the next document release.
