Temperature sensor in Tiva TM4C123BE6PM
Other Parts Discussed in Thread: TM4C123BE6PM
Hi all,
I read in data sheet of TM4C123BE6PM that it has an internal temperature sensor but data sheet does not mention any where what temperature does it measure. I am not asking the temperature range that it can measure. I want to know if it tells me the internal core temperature or I can sense temperature anywhere on my board using GPIO's.
Many thanks,
Ishan
  • This internal temperature measure springs from a P-N junction & some support circuitry w/in the MCU.  It provides a reasonable measure of the MCU's temperature - on/around that internal junction.
    It is accessed via the ADC module - it does absorb one (or more) of your ADC step sequences - but requires none of the ADC's pin resources.  It is detailed w/in the ADC section of your MCU manual.
    This internal MCU sensor measure is dominated by the MCU - it is our belief/finding that it provides only minor guidance as to your board temperature or that of nearby components.   External temperature sensors - accessed usually via one of the many serial communication provisions of these MCUs - is the normal means to make these extra-MCU temperature measurements...
