Other Parts Discussed in Thread: RM48L952, HALCOGEN
I want debugging my code. When I push the "debug as ---> 1 .code composer debug session", I got a error showed below.
CortexR4: Can't Run Target CPU: (Error -1141 @ 0x1FE) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.73.0)
I have tested the Jtag by push " test connect" button many times, The Jtag interface never failed.
The CCS can erase flash and program, but it just enter the debug status when the code is simple and some times it was dead at load sign after erase flash and some times CCS was stop by system.
I use the CCS 5.4.0.00091 , usb100v2-arm and HALCoGen 03.05.02 for my RM48L952 MCU PCB.
chuan
